Got in the car last night when I got kicked out the pub.
Started it up and the red light by the temp gauge stays on and flashes with some beeps... after about 5 mins fcuking about in the dark looking for user manual and stuff to find out what it might be I found that the coolant reservoir was a bit low (only just under min mark, so no big deal).
Anyway I topped it up to the full mark with some volvic that I luckily had lying about in the back of the car.
The manual says use G12 coolant at 40% (or upto 60%) and if you top up with water get the mixture sorted asap afterwards...
Am I right in thinking that means if there was a big fluid loss, and I don't need to worry as I only added about 1/4 litre of water.
Do I need to get some G12 (whatever that is) coolant to put in, or will it be ok? (assuming the level don't go down again).
