Front wheel bearing hub
Dec 18, 2019
Southampton
Hi, changing front near side wheel bearing and hub, first bearing needing change, not bad considering 150 k miles. All has come off fairly easily considering how rusted all has become in 17 years. The 3 fixing bolts securing the hub itself were in an awful state and rounded immediately. Can I grind the heads off and then beat hub/grounded studs off ? possibly I could change bearing only and leave in situ if not. Any advice much appreciated 👍
Dec 18, 2019
Southampton
Well, I won’t be grinding the heads off as bolt heads are countersunk ! Have seen people on YouTube grinding into the hubs themselves to sever the bolts, might be the way to go.
Dec 18, 2019
Southampton
I’ll post this in case anyone does a search sometime for help lol. Today I took a 4 inch grinder with a very thin dic and cut down behind the hubs far enough to sever all 3 fixing bolts, then with a hammer and bolster managed to separate bearing from steering knuckle, replacement was simple, so job done. Found out about this on a Skoda forum , so thanks to those guys 🤓
