No I kept my aircon, I live in Kent and it gets fooking hot in the summer down here!
Banksy you think it would add 15-20bhp?!
well if i made 357bhp on a standard intercooler then im sure a bigger cooler going add alot more.
Try and do a direct back to back test and see if it does really add anything.
RR with oe, rr with new
And on the road logging charge temps with both.
On a like for like - so both with aircon removed or not.
I'm not convinced in the slightest that you will gain anything like as much as 15 - 20 BHP just purely from the Intercooler change.
Don't get me wrong, every little helps and cooler is better, just not convinced you are going to see that big a difference. I've seen front mounts hurt power and spool all be it on other makes.
When you were running Revo software stage 2+ what timing were you abke to run with your eurojet cooler?Intercoolers dont' "give extra" power as such, they provide a cooling effect through added air flow, which in turn aids Intake Air Temperatures, which in turn helps with correction factor, which aids the advancement of timing for power consistancy
Why does the car have more punch to it through the mid/high range then?
So when winter rolls around I should be theoretically driving a Bugatti...![]()
I've bought an airtec stage 2 cooler and hoping to run timing 6 instead of 5
I only pulled 330bhp in the middle of summer on the standard intercooler on stage 2+ - APR v3.4, it was baking in and outside so I'm assuming the heat did my RR figures no favours
I'll have to get it back on the rollers to see if it had made much of a difference. Thanks WeeG![]()
