**Floppy aero wiper blades**
Scotty_b
Leon Cupra 300R
Jun 3, 2004
6,026
66
Hertfordshire
Went into hellfrauds to have a look today and they only had two sets on with two 21inch and an other with a 20 and 19inch £18 a set too
Stu_HR
Odd Member
Jun 9, 2005
293
Fitted a set from DriveForward to my Ibiza Cupra 16v on the weekend. Literally took 3 minutes! :thumbup:
Because the blades are different lengths from standard @ 2cm coverage on the outer arc of the passenger's side is lost but almost the entire height of the screen on the driver's side is now swept. I daresay the passenger blade could probably be adjusted but I don't feel its really worth it - hopefully the passenger won't be doing the driving. :whistle:
Sunday's weather here proved to be a good test of the floppy's abilities. Very impressive - excellent water dispersal characteristics, consistent across the length of both blades. No lifting at all at speed & so far nary a hint of a squeak - even with a dry screen. :D
Fl@pper
Jun 19, 2001
12,368
25
Gloucester
Forbez said:
What happened to the parts number from renault??
I cant find it anywhere, im sure it was on this thread.
it is now
( 77 11 236 179 - Renault part no)
sorry posted it on the other thread when i lost this one
Stu_HR
Odd Member
Jun 9, 2005
293
Okay chaps, some help needed here!
Having fitted a set of these lovely floppy blades to my Ibiza my girlfriend is sooo impressed that she has "asked" for one for her (don't laugh) Citroen AX - it only has one central wiper so it would be rather nice if it worked properly!
Anyone know if Renault does a 22" floppy blade? (Local Stealer was utterley unhelpful/clueless).
Fl@pper
Jun 19, 2001
12,368
25
Gloucester
ill check the list - you sure its a 22" ?? seems a bit large even for a single
from memory there was a kit with that size in it or damn close at least so you will have to get a pair again - but hey :) cut the spare one down for the rear on yours OR hers
better still your rear one :p
i'll check in the am - list is at work
Stu_HR
Odd Member
Jun 9, 2005
293
Many thanks, Flapper. I've checked & both GS&F & ECP quote 22" for the AX front wiper. Think I'll keep the second one for the rear on the old Ibiza! GF needed a new runabout asap & the AX with 12 months MOT, 6 months tax & a genuine 36k on the clock was too good to turn down for £575. :p
Forbez
Huge Member!
Feb 11, 2004
5,878
S.Wales
Cheers Flapper, i'll see if i can order some later,
Although, my local parts dept,is the same cardiff one that people are having trouble with. I'll try the newport one.
Scotty_b
Leon Cupra 300R
Jun 3, 2004
6,026
66
Hertfordshire
I had trouble with my local garage as they couldnt find the code, but them im sure when i walked in they were trying to decide which bit was there arse and what bit was there elbow!
Fl@pper
Jun 19, 2001
12,368
25
Gloucester
sorry to keep ya
been laid up with a slipped disc last few days
i'll sort it in the morning
W4YNE
HERE COMES LUNCH : - P
Jun 7, 2004
337
Midlands
Hi Chaps,
Sorry if I'm being a bit thick or lazy here, I had a set of Driveforwards aero wipers, but was around the time my little 'un was born & so as he hadn't heard from me, he flogged them to someone else (which is fair enough) :cry:
I now want to get hold of a set of these wipers can anyone point me in the right direction & is the code I need for an LCR; ( 77 11 236 179 - Renault part no) & how much £ :confused:
If not can someone show me the light please?
Many thanks in advance ;)
Fl@pper
Jun 19, 2001
12,368
25
Gloucester
thats the ones and should be about £30 odd from any GOOD Renault dealer
although you may need to perservere with them and ask them to check the number at the factory
for Stu HR - i'd use the same kit as above and cut down the long (24") one as a 22" is listed but in a pair for a vel satis :( and costs about £60 :(:(:(:( booooo
- plus i'm only 95% sure its the right style fitting - better safe than sorry
at least you have a rear one to fit then :)
Stu_HR
Odd Member
Jun 9, 2005
293
Many thanks Flapper - just in time for the rainy season!
Hope your back's not too bad now - I damaged discs in my back @ 10 years ago & its never been right since. :(
