Flashing oil light beeps no codes oil fine?
mikesndbs
603
23
West Sussex UK
www.youtube.com
Hi friends HELP. Was driving home car running great, suddenly oil/pressure light starts flashing and three loud beeps. Couldn't stop immediately due to roundabout. Light went off stopped. No codes. Oil level almost normal. Drove home. 7 miles and it came on again just as I pulled in. Any thoughts?
mty12345
4,107
680
bristol
Agree with what the other lads have said. Fairly easy job to remove the sump on these cars. Clean or replace the pick up pipe, common problem if oil changes have been neglected or sealant has made it's way into the sump. Low oil pressure doesn't set a code.
Nam-uk
1,270
416
lancashire.
you could do a oil engine flush but it can be risky sometimes, i did it on mine first time in 2011 but not done it since.. i used a forte engine flush as it was used in the industry then
