goin to fit my strut brace today am i correct that i have to drill my own 4 holes in the struts. also the bonnet sensor is in the way and the water bottle???
any ideas
any ideas
its not the engine water bottle is gettin in the way
the engine coolant is in the way ...and what i did is undo the bolt at the back ...loosen the bolt at the front, and turn the coolant tank a bit forward so there is enough clearence ...tighten the bolt at the front and the back bolt wont go through the coolant tank hole. but its tight, doesnt move at all. also the brake cap u need to loosen it and tighten it back up so its facing the back
Thats exactly what i had to do with the coolant bottle and i dont have a bolt at the back as it wouldnt go. So i put a cable tie throught both holes for extra piece of mind. I just had to move the wiring that goes to the top of the brake bottle cap as it was slightly in the way. Just turned it slightly to the left.
pmsl at the cable tie comment
