Fitting a subwoofer in a Leon Mk2
Audio Advice
custom boxes
Street
There used to be a guy not far from you but as far as I know he has closed now. Try and find a decent local Audio shop and they will be able to guide you the right way to make one or if budget permits get them to build something for you. Ask for pics (or see for yourself) some examples of their work first though. :)
Aug 11, 2008
487
Liverpool
Yeh think I might have to find someone.. I'm OK fitting things (fitted my new headunit and wired it up to the OEM bluetooth) but when it comes to actually building things I'd probably fail!
Going to have to wait a bit though.. Spent out a fortune the last couple months on headunit and ARBs!
alexangas
i think about £300 is a good budget...i used to have a rockford fosgate head unit in my old car but i gave it away to a friend. It was an excellent cd/mp3 player but i dont think they make them anymore!
Audio Advice
no bother
no bother - we could always do it for you but its a bit of a treck up the M6
Once you're ready let me know and I will try and guide you to someone nearer :)
Audio Advice
based
We are based in glasgow.
If you PM me your e-mail address I could send you a picture of our latest Leon install in which we have moulded an enclosure into the passengers side rear quarter in boot. Looks lovely - even if I say so myself ;)
Or you could e-mail us at [email protected]
I cant post pics as I'm a new member - but will do so once its possible :D
Iain
hon_n_gem
Candy White K1
Mar 22, 2006
1,132
Kent
www.auto-tuner.co.uk
Creating custom boxes are pretty simple, I did mine by using wheel diameter and fitting the biggest possible box into the round space. Then to make the false floor draw around the carpet and get the jigsaw out!
Heres mine in my old beeza:
Feb 1, 2010
987
Leicester
just finished fitting my sub and amp getting the wires in was a nightmare but made so much easier with the guide on page 1 . Top write up will reccomend it to people who are not good with ice installs like myself!
Zesnale
The cable should have an in-line fuse (no higher rating than the one on your amp) no more than 18” from the battery terminal.... Why should it have an inline fuse WITHIN no more than 18"??
just interested
Lukeyx
Rootmonkey
Nov 30, 2008
219
Grimsby
Having a nightmare installing sub&amp. The trims are soo hard to get off, also how the hell can you get the the rear speaker cables (in the door) to cut and connect the speaker wire for sub to?
matthewbentham
Cupra averaged 41mpg once
don't use a screwdriver to prise off the trim as this will damage it. Use a wide plastic lever or proper trim removal tool (search Amazon or eBay. they're about £3-5)
to install a sub, it's best if you have an aftermarket headunit (Pioneer, Kenwood etc) as these will usually have a dedicated sub-woofer output using standard phono/RCA connections so you can connect the headunit to your amplifier with ease. That's what I did.
Hope this helps,
Davros
I still have nightmares about getting the trims off, and that was over 4 years ago! I used an old knife wrapped in electrical tape.
I wouldn't try and tap the wires in the door (i don't know how you would do that) - tap them as they come out of the back of the head unit, run them into a line level convertor and then run the phono leads down the centre of the car to the boot.
Hope this helps!
Apr 4, 2011
572
woodford green
having done a few stealth boxes over the years in golf's and now in the altea , do have a look at the slim line pioneer subs really fab bass for a very shallow speaker & i still have all the space above the false floor free see my build thread for pix
i have a 12 inch sub in a 11cm deep box the 8 inch would make a great inside the spare wheel sub as it dont need much box volume to work
Lukeyx
Rootmonkey
Nov 30, 2008
219
Grimsby
I know the sub is 50xs more powerful as ive heard the same one in my mates car. I'm gonna test mine in his on wed, and then his on my setup to see if its all wired correctly.
Soo annoying when you have spent so much time lol
cila555
CiLA
Apr 2, 2010
234
Kosice - Slovakia
www.cila.sk
Hello boys,
in my car Leon 1P Cupra R I have: RNS 510, Dynaudio speakers and amplifier, sub JL 13TW5-3 with amplifier Genesis Profile1. As you know Genesis is (was) great sign but I have a little bit problem with connection HI LEVEL adapter for sub. Is somebody here who help me with contact on Genesis Service about help? I would like to ask you about help where I can find conector with correct connection. Many thanks for help ...
Apr 4, 2011
572
woodford green
Hello boys,
hi ya
as far as i am aware the company no longer trades , & if you want bits then ebay may be the best source
MM
