I'm looking at uprating the ICE & adding a sub too.
A friend has done this in his Meganne F1, sounds quite good too using a sealed enclosure & the false floor = boot space.
boot floor back in - and nobody would know
I haven't got a CD Changer or Ice>Link and have been stumped for a few days now on where to get a feed for the remote wire. Just found the 12v cigarette lighter seems to be suitable.
Can anyone see any reason why this won't work. I don't fancy taking apart the centre console to connect the remote to find it don't / won't work.
EDIT: All done and connected, remote feed from cigarette lighter works a treat.
Gareth
you said you got your feed from the cigarette lighter . . .
well that's a PERMANENT live so no wonder it works!!! (this is live even with the key out and the doors locked - therefore there will always be a current) this will be wasting you battery big time!
No no no - The lighter in mine does NOT work without the ignition on. So it should be fine...
Have you any details on this ? Very interested !!! I NEED BOOT SPACE.
I got the pinout from ELSAWIN (Seat workshop manuals - off eBay), but this may help you. I assume i used the +uB CDC - they were labelled differently on ELSAWIN. I'd check, but i've reformatted my PC since then and haven't installed it again.
If it doesn't work, give me a shout and i can pull my radio out and check, but i'm without my car for a couple of days
you not changing your head unit?
