i heard u had to leave it in cuz the wiring lume is part of the climate control??
or was the kiddy i was talking to talking bollocks
That definitely sounds like he was talking about the Ibiza!
Don't forget to order a power aerial adaptor with the fascia and wiring, or you'll never get the best signal on the radio
forgive me for being slow......but very tired but whats a power aerial adaptor? my radio signal is pants!
Is that the same blue wire that would be used as a remote for the a sub and amp?
The standard aerial in the Leon is amplified for a better, strong signal. If you want to keep this working, you need a small adaptor that uses an external power supply to power it, now the OE headunit has gone.
These cost less than a tenner and are easy to wire in. They are wired into either the blue or blue/white striped wire from your head unit. One of them will say remote turn on, powered aerial or something similar. Simply wire it into that and plug the aerial in and you're done
