fault codes
redline69
help need advice on some fault codes on my seat leon cupra r
fault codes are 17704/p1296 and 17705/p1297. car feels slow,also sometimes when u start it up it idles at 3000rpm.any 1 got any ideas thanks
sambryant
RoadRunner meep meep
Mar 26, 2009
4,848
Bristol
17704 thats the temp sensor or stat gone or may be both. also check for a air lock. 17705 is a boost leak between throttle and dump valve. check your dump valve and check for split hoses.
redline69
thanks mate,willl have a look later.might change dump valve anyway as still standard 1 on it and car has had stage 2 remap so may bennefit better dump valve. where is the most likely place 2 find split hoses? thanks again
redline69
what is the best dump valve 2 replace the original 1 with?:confused:
redline69
just tried looking for split hoses,but dont know where 2 start looking. Anyone got any idea which are the most common hoses 2 split. THANKS:D
redline69
not yet mate,just thought i would try eliminating hoses first,before spending out on dump valve
adam cupra 20vt
Built Not Bought.
Mar 31, 2005
6,162
Mud Hut
You really need an uprated valve on a stage2, for all you know the boost leak could actually be the valve as they quite often fail.
redline69
cheers mate,will get 1 next week and let u know if it sorts the problem. also still got standard TIP could this be causing problems with stage 2?
wayne lcr
bored of it now
Mar 5, 2009
4,548
doncaster
what modds you got to run a stage to? cos alot of this should have been changed before the stand tip is pants it fails at 5000 rpm and you really need to upgrade these asap
redline69
I bought the car off my mate.He had done remap but left everything else standard! it was pushing 286bhp when i bought it,doesnt feel anywhere near that now though:(
