Fault code & maf logs LCR
Ju.
461
Bradford
Recently started "playing" with vagcom and have found the odd fault code. I had an intermittent misfire(can't remember the code) which I deleted a week ago and hasn't returned but now I've got this one:-
16396 - Bank 1: Camshaft A (Intake): Advance Setpoint not Reached (Over-Retarded)
P0012 - 35-10 - - - Intermittent
Also did a log:-
Group A: '003
RPM Mass Flow Load Ign. Timing
TIME
Marker STAMP /min g/s % °BTDC
102.5 2120 43.11 92.2 21
102.9 2240 52.86 94.5 9
103.3 2400 64.28 97.3 15.8
103.69 2600 81.67 100 10.5
104.11 2800 93.89 100 1.5
104.51 3040 101.28 100 4.5
104.91 3280 121.25 100 3.8
105.31 3520 133.81 100 5.3
105.71 3840 144.75 100 6.8
106.11 4120 144 100 8.3
106.53 4360 154.69 100 9
106.93 4640 152.64 100 12
107.33 4880 160.44 100 10.5
107.73 5120 172.47 100 11.3
108.13 5360 180.61 100 12
108.64 5600 183.47 100 11.3
109.04 5760 182.44 99.2 10.5
109.45 5960 183.03 99.2 10.5
109.95 6120 118.78 25.9 13.5
The car is an Apr stage 1 remapped LCR with Dynatwist and Samco TIP, should I be seeing more airflow?
any comments would be appreciated
Julian
bentaw
Revo'd LCR
Oct 1, 2004
1,067
Hampshire
i would say you should at least see 190 to maybe a 200 as that is what i have seen before what gear was that in
Ju.
461
Bradford
That was a 3rd gear run, don't really have a suitable road to do 4th gear run.
My map is for 95ron, would it be worth adding the 98ron program?
bentaw
Revo'd LCR
Oct 1, 2004
1,067
Hampshire
yes mate better for your car i have not put one drop of 95 ron fuel in my car since i had revo installed i dont know much about the APR remap but i would say try the 98 ron program and see how you get on
