But i have yet to see a decent RR figure on Revo Stage 2 with a k03s.
Has anyone got over 230bhp with this setup?
lol yes but why though
Who?
A car with a custom jabba map should have better figures all the way through the rev range not just peak bhp which is why it probably would pull away quite easily against a revo stage2ko3s even if it was correctly set up...correct?
Has anyone dyno'd a revo stage 2 with a k03s? I dont think i've ever seen a post about it.
Am I the only one that thinks a Forge Actuator on a K03s setup is the magic component for the 250bhp numbers then?
im fitting a full blue flame system turbo back when it turns up mines goes off to jabba for a custom map and 4 bar fuel reg on july 9th we will see what that brings
personally unless or see it for myself and i know both drivers are going as hard as each other, then i call it bull
just how custom is a custom remap.....not very at all really
and there are just as many people who know this as there are that think that they need a custom remap because they fitted a new cat back exhaust system and dv
you really need to see past revo, Yes revo is a good map we all no that, but the difference between my mates revo stage 2 ko3s golf, at higher rpm is huge compared to my jabba ibiza. I know that his is a little heavier than mine but i can pull away from him in 3rd gear pretty easily
possibly the difference with the ibizas is that revo stage 2 is mapped for a k03 turbo where the jabba map is a little more custom to the k03s
but the rr results show (choose to believe them or not) that there is quite alot of jabba ibiza's hitting 250bhp or there abouts, and the revo ibiza's to a similar spec just are not getting the same results
maybe its all a big conspiracy....lol
i do believe that with a k03s , revo stage 2 seems a little conservative and that is when you can benefit 90% of the time from someone who should know what they are doing and have the ability to push the tubo more. i've seen it for myself with phil and daz's logging that revo isnt quite pushing the turbo enough. but that is it.
however i also believe that a well set up revo k03 wouldnt have much problem keeping up with a revo stage 2 k03s or custom mapped k03s. ok not side by side...that would be daft. but not dramatically behind...not enough for a third person to go 'wow' any way. BUT before i get jumped on I am not saying it would be just as quick, just not far behind
I know what you mean Karl, been there so many times with the "usual suspects" who rubbish the RR claims, especially when it comes down to the K03s
