EPC light came on today, no boost atall. Restarted, still the same. Restarted once more, EPC light went out but the management light came on. Boosting fine again.
Will get vagcom on it as soon as I can but anyone got any guesses?
this happened to my LCR aswell took it to seat and they said it was ECU after i had changed the pedal it was still the same.i stripped the car down to find the ECU under the wipers there was a broken wire from ecu to pedal connector re wired it up and alls fine now
Holy cow, this is a blast from the past.. mine turned out to be the throttle wire going back to the ECU that i had snagged when putting in a boost gauge so just re-soldered it.
