EPC light and loss of boost
speedsix
Leon Cupra R 225
Oct 30, 2004
825
EPC light came on today, no boost atall. Restarted, still the same. Restarted once more, EPC light went out but the management light came on. Boosting fine again.
Will get vagcom on it as soon as I can but anyone got any guesses?
CupraMVR
Awesome GTi Technician
Oct 19, 2006
1,371
Crewe Cheshire
this happened to my LCR aswell took it to seat and they said it was ECU after i had changed the pedal it was still the same.i stripped the car down to find the ECU under the wipers there was a broken wire from ecu to pedal connector re wired it up and alls fine now
speedsix
Leon Cupra R 225
Oct 30, 2004
825
I will have a look into this as it did it for the second time today.
1 Fault Found:
18047 - Accelerator Position Sensor 1/2 (G79/G185): Implausible Signal
P1639 - 35-10 - - - Intermittent
Any tips for getting access to the ecu?
johnboy98
106
Newquay
1 Fault Found:
Ive got the same problem mate what was the outcome or have you still got the boost/epc issues?
johnboy98
106
Newquay
Holy cow, this is a blast from the past.. mine turned out to be the throttle wire going back to the ECU that i had snagged when putting in a boost gauge so just re-soldered it.
