Hi Guys,
I have a 2L 8V that has been getting progressively worse.
Historically, when you stopped driving and put the clutch down the revs would fall and it would nearly stall, dimming all the lights and cluster etc. (i say driving because it was always fine when stationary in neutral, blipping the throttle??!)
Now however, its become so bad that it wont idle unless you release the throttle SERIOUSLY slowly, even on idle. It will start, you have to catch the revs with the throttle it will rev nicely, then die if you try and make it idle.
I have checked the breather and crank pipes, they were full of mayo like stuff which i cleared
I have also cleaned the ICV with carb cleaner.
I am running out of things to try and my local garage has also failed... any ideas? Thanks guys
