engine running question
chris285
leon mk1 fr tdi
Nov 26, 2004
1,849
lincoln, uk
my 1.4 99 plateis not running correctly, more specifically when running at lower rpm's below around 2k or so
idling is not correct its not smooth and reversing down the drive cause the rev's to drop from normal to around 500 or less and it jumps back up again
it was doing this a few weeks ago but much worse, then had the rotar arm and dist cap replaced and much better but still not right.
car is just coming up to 80k on the clock and has been about 12k since last service so going to get it done again, could this be ignition leads need replacing as i am not sure they ever have been
EssexIbiza1985
293
I have a similar problem with mine. it seems to get stuck around 500 rpm sumtimes until it bounces back up again or i give it a bit of gas. If sum1 knows or could spread sum light on the matter i wud appreciate it too.
swifty
if it was serviced 12k ago, i would suggest the plugs need changing depending what type/price plugs were put in.
