Model Year 23/24 Electric plug flap doesn't close in icing conditions
Cupra_33
58
8
France
Hi,
It's been 4 or 5 times that I can't close the electric plug flap in icing conditions.
Each time our Formentor is being charged over night in cold / frosty conditions, I really struggle with closing the electric plug flap after removing the cable.
I need to spray some alcohol to defrost the inside of the flap. Surprisingly, the locking pin has a complete normal behavior, it fully stows and rotates when I push it.
Does anyone face the same problem and has found a solution?
TIA.
Cupra_33
58
8
France
Hi,
On my side, I have no problem with the push pin. It's the flap that doesn't hook on the pin.
I'll check next time it's icy over here. But it seems there could be a kind of ice drop on the flap, where the push pin is to hook. :unsure:
koush
297
Churchdown,Gloucester
From what remember the pin twists 90 degrees as it is being pushed in and clips onto the flap. When it's cold / icy the pin pushes in, but does not twist.
Cupra_33
58
8
France
That’s right. But mine twists perfectly.
That’s why I don’t understand what’s going wrong…
