Dyno Twist Filters Are They Any Good.
danscupra
cupradan
Jul 16, 2006
64
Hi Every One Ive Been Thinking Of Buying A Dyno Twist Filter But Was Put Of Buy A Freind He Said That There Is A Chance It Could Suck Up Water Cause The Cold Air Feed Is In The Bottom Of The Bumper Could You Guys Tell ME How True This Is And Your Experiences With This Filter .
Thanks Very Much Dan
MarkE
Acceptable in the 80s
Jul 20, 2003
1,705
Lancaster
www.markeaston.org
What's With The Capital Letters At The Start Of Every Word?
In answer to your question, though, any intake system stands a chance of ingesting water if it's pulling an air feed from low down. Nothing to do with running a Dynatwist, IMO.
danscupra
cupradan
Jul 16, 2006
64
Sory forgot to take caps lock off . Do you know what would happen if it did suck water up my mate said chances are it would write the engine off really dont want that but i do really want a good filter for perfomance as i have a fuew plans for more power .
Thanks Dan
MarkE
Jul 20, 2003
1,705
Lancaster
www.markeaston.org
Your engine works by pulling air into the cylinders, injecting fuel, compressing the mixture and igniting it, forcing the pistons out again and creating drive.
Unlike air, water doesn't really compress very well so the outcome could well be bent bits in your engine.
Not sure where the standard Ibiza 3 intake is pulling its feed from. If yours is standard then there's plenty of owners out there running Dynatwist (or similar) induction kits without problems. If yours isn't standard, does it really need to pull an air feed from low down?
danscupra
cupradan
Jul 16, 2006
64
When i brought the car came with a K N its not very good as it sucks in lots of hot air cause its right in the engine bay i thought the lower u could get a cold air feed the coller the air would be i suppose if every one else runs these filters they must be ok well i hope really dont want my engine wrecked cause of a big puddle guess i would have to avoid puddles as much as possible.
MarkE
Jul 20, 2003
1,705
Lancaster
www.markeaston.org
I used to run a RamAir induction kit in my Leon, feeding from the standard inlet in the grille. The benefit of enclosed filters like the Dynatwist and RamAir is that (unlike an open cone filter) they don't pull in hot air from the engine bay.
It probably makes very little difference whether you pull your airfeed from the grille or the floor but taking the feed from higher up means that you won't need to avoid puddles. And there's plenty to avoid in this country at the moment.
danscupra
cupradan
Jul 16, 2006
64
Yeah i would like to put a cold air feed in the grille but is there any room for one. Do you know any one with seat ibiza cupra 20v turbo with cold feed to grille.
Nov 2, 2004
9,335
South Wales
Smooth airbox, decent panel filter and a large cold air feed.
Or if you have to have one, get a ramair maxflow from Badger 5. A lot cheaper than a dynatwist and looks/does the same thing.
danscupra
cupradan
Jul 16, 2006
64
Just wanted to ay thanks for the replys to my question very help full .
I think i will go with dyno twist in silver to match my polished engine parts thanks again every one.
ibizacupra
Jack-RIP my little Friend
Jul 25, 2001
31,333
19
glos.uk
they are good, they dont suck from low down unless YOU stick the intake pipe there.
Ninja
Cupra now gone :(
Oct 1, 2005
1,182
Reading
www.peugeot-gti.net
as said above just put the air feed where it isnt gonna get wet!
Mines been fine with the air feed into the wing where the standard intake is.. Would like to try it somewhere its gonna get more air but not sure where to relocate it yet !
Dec 31, 2005
1,856
London
was thinking about putting the airbox intake where the smic intake used to be, is this not a good idea then? never thought about the water issue before.....
ibizacupra
Jul 25, 2001
31,333
19
glos.uk
think deep puddles when locating the feed pipe.
on ibiza's the std position is a goo done... the air gets fed into the top of the wing, base of windscreen at speed as its a high pressure point forcing air into that cavity. up and out the way of wet & stuff also.
my advised placement.
Ralph007
93
BADGER - whats this Ramair maxflow that Philw mentioned?? Any good?? Can't find refernce to it on your site - prices/info/pics??
Ralph
