Dump Valves
icestorm81
506
115
Dorset, Dorchester
I do have fault codes on the ECU as i was going to have the car remapped at the same place where they fitted the dump valve. They said to me, that they would have to send the ECU off to sort the problem out. So if i take the baileys dump valve off and put a forge 007p one on instead it should clear the fault codes. The place in queation where i had the work done was performance 3000 up in yeovil, and they are well know to **** peoples cars up, if iv know b4 hand i would never set foot in the place!
jonnym1981
hi ive been looking at what to get, was told by a good friend who had one that i should get an adjustable recirc valve. all the ones ive seen so far seem to be none adjustable? any thoughts?
sambryant
RoadRunner meep meep
Mar 26, 2009
4,848
Bristol
the 007 is adjustable in the fact you can change the springs to suit your boost levels, also they sell shims to fine tune.
if standard boost then you want a green spring
mapped boost then you want a yellow spring :)
