I'd recommend running the DV the correct way around otherwise it's likely to leak
lordgibbness Mar 29, 2007 1,207 1 Berkshire Jun 26, 2009 #21 I'd recommend running the DV the correct way around otherwise it's likely to leak
DJ-LIAMC VAGisclean May 31, 2009 656 0 Loughborough Jun 26, 2009 #22 has anyone used the 007p without ant washer plates , just the spring ?
lordgibbness Mar 29, 2007 1,207 1 Berkshire Jun 26, 2009 #23 I thought the plates were just to add tension between spring colour ratings?
DJ-LIAMC VAGisclean May 31, 2009 656 0 Loughborough Jun 26, 2009 #24 well i hope so cause i aint got 1 in and ther dv doesnt make any noise at all?
Mylo Aug 24, 2007 800 0 Jun 26, 2009 #25 the 007 is not meant to make much noise A remap, open cone or modded air box will help but it's still a stealth mod. A green spring on its own is correct.
