DSG: Paddles dont react
mykro
75
7
Sometimes it happens that paddles under steering wheel dont react on order to increasing or decreasing engaged gear. Nothing happen. I need to press down gearbox lever in order to swich to S mode (from D), and back to D and then it become functional. What kind of problem is it ? Lets say it is once per 500km.
6 dsg ds250, 4x4 leon 2015
mykro
75
7
sometimes i had a bunch of errors, wtf?
13 Faults Found:
21153 - Gear 1
P072C 00 [002] - Not Selectable
Intermittent - Not Confirmed - Tested Since Memory Clear
21154 - Gear 2
P072D 00 [002] - Not Selectable
21155 - Gear 3
P072E 00 [002] - Not Selectable
21156 - Gear 4
P072F 00 [002] - Not Selectable
21157 - Gear 5
P073A 00 [002] - Not Selectable
21158 - Gear 6
P073B 00 [002] - Not Selectable
21159 - Gear R
P072B 00 [002] - Not Selectable
10731 - Valve 3 in Transmission Part 1
P174A 00 [002] - Electrical malfunction
10732 - Valve 3 in Transmission Part 2
P174E 00 [002] - Electrical malfunction
10657 - RPM Signal from ECU
P0726 00 [002] - Implausible Signal
10739 - Valve 3 in Transmission Part 1
10909 - Cooling Oil Valve
P179D 00 [002] - Electrical Malfunction
10906 - Cooling Oil Valve
I saw on the internet that these error appears when scanning for error when engine is running.... so hopefully this is problem of scanner
Tell
Normally you scan when the engine is running...
Pass on the paddles but grabbing the lever and toggling it to S and D fixes the gear selection if your fingers hit the paddle lever on a roundabout and you get stuck in gear. Happens sometimes so the quick fix to restore is the -> S -> D or swap D to S which ever you were in before sorts it out.
