drivers seat not adjusting
al20v
120
Hi All, help needed i cannot move my seat back and forward. The clip is broken, see pic.
Does anyone have etka to see if I can find a pn. Please tell me this can be repaired..
I did a search and couldn't find a thread, but someone must have come across this before?
Bouncerbeater
Old enough to know better
Mar 15, 2013
1,303
Gloucestershire
Can you identify which part from this catalogue pic ?
stevepx
55
Southampton
Re-raise this thread.. Sorry!! Looks like exactly the same issue I'm having with the front passenger seat. It was pushed all the way back on the runners and now will not move forward. I have had a very quick look under the seat and seems the same thing is broken on mine. Is this an easy fix, do I have to take the seat completely out of the car and if so how can I do that with the seat pushed all the way back.. So many questions.. So many issues.. thought these VW based cars were supposed to be well made, my Alfa is put together better.. And that's saying something... I have a broken rear nearside door module which leaves the door unusable.. to boot locks only when it wants to and a I have a EML fault relating to "Air Injection" which I presume is a leaky hose.. Only had the thing a month or so and already starting to think this is more work that I bargained for.. Anyway, rant over if I could get a little advice on the seat issue that would be great.. Thanks..
Bigjohn84
Intagram / johnyoung84
May 5, 2015
2,330
That's what happens when you buy a second hand car mate, we have all had the same problems ur having, not the seat problem tho. My cars never getting sold, spent to much time and money on it like most of us, no ones ever benefiting from my work, just passed mot today with two advisories brilliant
stevepx
55
Southampton
Yeah I know Bigjohn.. just a little frustrated... was that coming across!!!:) So do you know if its a seat out job? Thanks
Bigjohn84
May 5, 2015
2,330
Yeh u will need to take the seat out mate, u should be able to get it forward somehow,
al20v
120
Agreeing with above poster. I had to take my seat out.
Look uder the working seat to see what cable is pulled to move the seat. .use a pliers or vice grip and you will be able to shift the seat.
Seat removal is handy enough. Two 13 mm nuts under the front if I recall right.
Remove the covers over the runners.
I found the black caps over the screws to be a pain.
Disconnect the cables.
Pull seat forward until it comes off the runners.
I got it out through back door.
Once the seat is up on the bench it's easier to work on.
My dad was giving me a hand to push the new cable in I was getting a little cross at it turned away for a second and he had it in. .
So maybe a little patience needed ;)
stevepx
55
Southampton
Brilliant al20v thank you for the information. Think the actual item broken on mine is 12b on the diagram above. Thank you again..
