Agreeing with above poster. I had to take my seat out.
Look uder the working seat to see what cable is pulled to move the seat. .use a pliers or vice grip and you will be able to shift the seat.
Seat removal is handy enough. Two 13 mm nuts under the front if I recall right.
Remove the covers over the runners.
I found the black caps over the screws to be a pain.
Disconnect the cables.
Pull seat forward until it comes off the runners.
I got it out through back door.
Once the seat is up on the bench it's easier to work on.
My dad was giving me a hand to push the new cable in I was getting a little cross at it turned away for a second and he had it in. .
So maybe a little patience needed
