Drivers electric window wont go down using one touch.
vicki1981
I have just noticed that my drivers side window will not got down using the one touch but it will go back up with the one touch.
What can be the problem. It will go down if i keep pressing the button or hold it down. Somebody told me to keep the buton pushed up for 5 seconds after closing and then let go and push back up for another 5 seconds to reset the window but this has done nothing.
Any help with this is very much appreciated.
Vicki.
Marshall
3,256
Bonnie Scotland
Try holding the button down to put the window down when at the bottom hold for 5 secs then back up and hold for 5 secs that should work.
vicki1981
Thanks very much but ive just tried that and its just the same. Any other ideas. Cant understand why it goes up one touch but not down:shrug:
Vicki
don shaleone
146
Coventry
whenever Ive had that problem I put um down a bit, then all the way up until it stops let go, then press up again for a few seconds and u feel it reset well kind of
vicki1981
Thank you, Ive just been and tried that aswell and like you say you can hear it reset but its still just the same.:confused:
Vicki.
vicki1981
Yeah its always been fine, just noticed it not working properly today. Dont know if it makes any difference but mines a 56 leon reference sport 2.0.
Would take it to the garage but I know what some can be like when they see a lady(lets rip her off and say it needs all these new things and its maybe just a fuse or something daft).
Vicki.
Marshall
3,256
Bonnie Scotland
You could try this. If your car has remote locking hold the unlock button to open all the windows then hold the lock button to put them all up again.
See if the window in question works or not.
Sent from my HTC Desire using Tapatalk
vicki1981
I tried this last night and if I keep the button held down both windows work and then they will both go up fine but drivers side still wont work on one touch:confused:
Vicki.
cozmeister
Has the second stage for the switch broken or maybe somehow got gummed up ?
adam1811
Stockport - Black 2.0 TDI
Mar 18, 2011
170
Stockport
Vicki.
I have a very similar issue, where my drivers side will occasionally go down one touch but most of the time it wont do... but it will come back up with the one touch motion!
Really cant understand why it does this have tried all the resets, am going to disconect the plug tonight and clean the contacts to see if that works. Could be worth a try for you?
vicki1981
Wheres the plug and how do you get to it? Im going to give disconnecting the battery a go and see. Will disconnecting the battery upset anything in the car?
Kind regards,
Vicki.
adam1811
Mar 18, 2011
170
Stockport
Kind regards,
Vicki.
What i mean by the plug is, under the switch on the main controls in the door panel. If you pop the switches out wiht a flat headed scewie and then remove the plug from underneath and give it a clean.
If you disconect the battery for longer than ten minutes make sure you take the car out for a good 30 minute run to pick up all the settings for the various parts on the car. Shouldnt give you any issues though.
vicki1981
lol, Will need to buy a haynes manual to work out how to get door card off. I am ok at these things as replaced my full front bumper on my peugeot but had a haynes manual. Wouldnt have managed without one.
Kind regards
Vicki
Marshall
3,256
Bonnie Scotland
If you disconnect the batter make sure you have keys with you and not lying in the car. Just incase it decided to lock itself.
Leave the battery off for 5 or 10 minutes on connection and startup you will get the steering warning light and abs which will go off once driven about 10 metres and that's it.
adam1811
Mar 18, 2011
170
Stockport
Kind regards
Vicki
You shouldnt need to take the door card off to get to the plug, just pop the switches out and the plug will come up with them. Just detatch the plug and then your laughing... :)
Give them a clean and then pop back into place.
vicki1981
Had a go at trying to pop the switches out but its a no go, looks like I will have to take the door card off to get too it:(
Kind regards
Vicki.
