mchubb
98
Bristol
Just wondered how easy it is to change the drivers side wing mirror???
Only the wing mirror seems to have lost all its colour, and have tried polishing/waxing etc numerus times but have had no luck getting it back to the level of colour of the other side/rest of the paint work, so wondered if it was easy to change, if I had another cover??
Matt
you don't have to change it, just take the top part of the wing mirror off (clipped on) and get that resprayed or re spay it yourself
cool thanks for that, didnt want to start hacking it off, if it was gonna be difficult to get off, cheers
takleberry you are incorrect i have this model my self and have changed the outside tempeture sensor which is in the passager wingmirror.. they dont just clip off on the older adition seats...you have to remove the mirror glass which can break be careful. there are some screws behind the glass and they hold the cover on this can be very tricky to do and if you are not very well trained on cars i dnt think you should atemped this urself just incase you break somthing..you see if a garage breaks somthing it there fault they replace it!
