Put a little bit of thought into the coldside run. I raided the LCR pipe kit again for a couple of 45 degree silicons, but I think I managed to keep it short.
It was fun taking it for a drive like this - you do get funny looks!
In all honesty, I had a real fight to get the bumper back on. The pre-facelift doesn't fit over the LCR intercooler. I had to get my jigsaw out to effect a temporary solution. It's currently bulging around the top grilles because the moulding along the bottom (original) grille is tight against the intercooler bottom. I'm going to have to carve some of that away. You'll see from the next photo (sorry about the light) that the bottom part of the intercooler is blocked.
I did manage some logs with the front on, though....
19 degrees outside temp
LB9 T5
Code:
Sunday 22 July 2007 20:24:33
06A 906 032 HN 1.8L R4/5VT 0002
'003 Group B: '020
Idle speed Air mass in Throt Angle Ignit Angle Idle Stabilization Idle Stabilization Idle Stabilization Idle Stabilization
/min g/s % °BTDC CF CF CF CF
2440 28.75 18 26.3 0 0 0 1.5
2520 38.11 31.4 26.3 0 0 0 0
2680 49.94 97.3 26.3 0 0 0 0
2880 56.42 100 25.5 0 0 0 0
3120 63.75 100 24.8 0 0 0 0
3360 74.08 100 24 0 0 0 0
3600 88.86 100 22.5 0 0 0 0
3880 107.47 100 18.8 0 0 0 0
4240 131.25 100 15.8 0 0 0 0
4680 153.75 100 9.8 0 0 0 0
5000 171.89 100 10.5 0 0 0 0
5400 177.36 100 10.5 0 0 0 0
5720 187.58 100 12 0 0 0 0
6000 191 100 12.8 0 0 0 0
6280 195.69 100 13.5 0 0 0 0
6520 193.58 100 14.3 0 0 0 0
Code:
Sunday 22 July 2007 20:27:22
Group A: '115 Group B: '031
Engine Speed Engine Load Spec. Boost Actual Boost Lambda Factor Lambda Factor
/min % mbar mbar
3000 51.9 990 1080 0.977 1
3080 77.4 1930 1080 0.875 0.969
3200 96.2 1960 1290 0.922 0.914
3400 109.8 2020 1460 0.852 0.836
3680 124.1 2090 1630 0.821 0.828
3920 138.3 2190 1820 0.813 0.813
4280 155.6 2230 2090 0.797 0.805
4760 172.9 2250 2310 0.789 0.805
5120 181.2 2230 2350 0.789 0.805
5520 175.2 2230 2220 0.797 0.805
5840 169.9 2220 2220 0.797 0.805
6160 165.4 2230 2160 0.797 0.805
6400 160.9 2250 2170 0.789 0.805
6680 157.9 2240 2270 0.789 0.805
Code:
Sunday 22 July 2007 20:30:10
Group A: '118 Group B: '032
Engine Speed Air Temp In Boost Dut Cyc Actual Boost Idle O2 Adapt Run O2 Adapt
/min °C % mbar % %
2840 23 0 1020 1.9 1.6
2920 23 100 1080 1.9 1.6
3080 22 100 1270 1.9 1.6
3280 21 100 1420 1.9 1.6
3520 21 100 1540 1.9 1.6
3880 21 100 1780 1.9 1.6
4240 21 64.7 2020 1.9 1.6
4640 22 58 2200 1.9 1.6
5080 23 51.4 2350 1.9 1.6
5480 24 42.4 2270 1.9 1.6
5880 25 42.4 2180 1.9 1.6
6160 27 45.5 2210 1.9 1.6
6440 27 49.4 2220 1.9 1.6
6720 29 49 2250 1.9 1.6
6960 30 47.1 2170 1.9 1.6
5960 27 0 1290 1.9 1.6
5160 24 0 1090 1.9 1.6
