When driving and the passenger door is rattling, if i reach over and put pressire on the door trim the rattle stops. Is this the same rattle everyone else has?
i find this stuff helps
http://www.toolstation.com/shop/p21...=46335364223&gclid=CNODjsygrcQCFQLMtAodP3UAFw
mine did this it was the rubber window seal against the glass
Interesting...spraying it down into the window hole?
If i push my door anywhere it stops the rattle so maybe this is different? For example i could push on the cloth around the handle and it stops.
So ive been doing some prodding of the passenger door and i think i might have found the source of the rattle. I have taken a video of it, hopefully you can hear that when you poke the card it makes a tapping noise (turn it up!). The drivers door does not do this.
https://www.youtube.com/watch?v=4j6itJjuxH8
Is this a fault anyone else has had? Is there a homemade solution like sticking some felt somewhere or do i need to go to the dealer?
There is a TPI for it fella, take it to the dealer where they will fit a kit or replace the door card. Just had mine done.
Excellent. New owner of a second hand mk3 so not actually been to my local dealer yet!
Im guessing a TPI is a recognised fault? IS there a number i need to quote?
These door cards are built from lots of sections welded together more than likely the sticky back foam I fitted stopped mine rattling.There is a TPI for it fella, take it to the dealer where they will fit a kit or replace the door card. Just had mine done.
