door locking/opening problem....??
freekie
21
Leicester
Facelift drivers door is 1P2837016
Just been delivered today. Hopefully the weather won't be too bad this weekend.
Sent from my LG-H815 using Tapatalk
freekie
21
Leicester
On the facelift model the door latch changed. Early facelift have the old latch with 9 pins 1P2837016 (drivers door) in the electrical connector while the later ones have 7 pins 1P2837016B (drivers door).
Doesn't make it easy.
James_3
Speed Blue
Sep 1, 2006
72
N. Lincolnshire
Got the same issue on my rear left door not unlocking from outside seems to be a common fault with the lock module. The parts changed in 2011 and newer ones have a D which will not fit
Pre 2011 is 1P0 839 015 - rear left (or 016 for rear right)
2011 on is Revision D so 1P0 839 015 D.
Also just wanted to add there is definitely no way of repairing these if they go wrong, I have taken my lock apart just to see what was inside and the electronics are not accessible as they are covered in hard plastic to keep it waterproof so it is not possible to replace microswitches or re solder anything like the older modules on MK4 golfs for example. Also as they stopped using the part in 2010 I have decided against going for a salvage part as they will all be 6+ years old parts and could easily be liable to the same failure.
You will need an M8 Spline bit - I got a set from halfords.
sfmk2.
878
As far as i know this is an issue with the locking mechanism on the door itself. My passenger front does it, but only when it's cold out. Lol. In summer it works again.
I'll be putting a new locking mech in myself when it finally buys the farm, no way I'll be letting the stealer do it.
JMF894
286
Norfolk
Another here with similar issue.
Front passenger sometimes unlocks with remote, sometimes doesn't.
2008 FR
James_3
Speed Blue
Sep 1, 2006
72
N. Lincolnshire
This is what VCDS said on mine:
not sure if it means the front passenger has an issue too - will re scan it after fitting the rear.
Part for front passenger is 1P2 837 015 (016 for drivers side)
Code:
Address 52: Door Elect, Pass. (J387)       Labels: 3C0-959-70X-GEN4.clb
   Part No SW: 1T0 959 702 AC    HW: 3C0 959 792 A
   Component: TUER-SG BT    002 0312
   Revision: 14101005    Serial number: 0000460940
   Coding: 0012B0
   Shop #: WSC 99999 1023 2097151
   ASAM Dataset: EV_DCU52BrosePasseSide A03004
   ROD: EV_DCU52BrosePasseSide.rod
   VCID: 79F90B6FF82C89D6D3D-802C
   Slave Passenger:
   Subsystem 1 - Part No SW: 1K0 959 703 AF    HW: 1K0 959 795 S
   Component: J388__TSG-HL  006 1401
   Serial number: 00000004714429
   Coding: 000290
4 Faults Found:
67074 - Motors for Central Locking
          B122B 01 [008] - Electrical Failure
          Intermittent - Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Status: 00000001
                    Fault Priority: 2
                    Fault Frequency: 2
                    Reset counter: 140
                    Mileage: 79809 km
                    Date: 2067.14.01
                    Time: 08:57:11
67330 - Switch for Central Locking
          B122D 29 [008] - Signal Implausible
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 49
                    Mileage: 79224 km
                    Date: 2065.14.24
                    Time: 09:03:43
132610 - Motors for Rear Central Locking
          B122C 01 [009] - Electrical Failure
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 13
                    Reset counter: 100
132866 - Switch for Rear Central Locking
          B122E 29 [009] - Signal Implausible
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 6
                    Reset counter: 103
                    Mileage: 79712 km
                    Date: 2066.14.30
                    Time: 12:23:54
