1) there are 3 torx bolts at the bottom of the door card - undo these.
2) there are 2 big philips bolts behind the grab handle cover - undo these. On the drivers side they might be obscured by the electric window switch...pop this out upwards once you've undone the screws and disconnect the lead.
3) undo all the clips around the door card by getting the bottom of the card and pulling it outwards. Take care with the clips, don't be too harsh with them!
4) bash the door card from the bottom so that it comes apart from the window seal.
5) undo the door handle cable and the mirror adjuster lead.
6) done!
