Im still having problems with her and i just dont know what is wrong
I left my car at home when i was holiday in the end as i didnt want to risk it breaking down again after that happening twice before i went away
I had a new Temperature Sensor fitted before i went on holiday and its no different so that is ruled out
I had the hoses checked and put back to standard on Saturday but the car is still pulling back so that is ruled out
It seems a bit lumpy on start up from cold and in general, only VERY slightly but surges a bit
When i take it to 4000RPM it judders a bit and then pulls right back before even getting to 5000RPM
We took the MAF out and put it into limp mode and it seemed better than when it was in but seemed to judder a bit at about 2000RPM and still pulled back a bit
I had another Ibiza Cupras N75 Valve on yesterday and it did pull right through to 6000RPM as normal but the fault code is still coming up?
I started it this morning from cold and it was REALLY lumpy and misfired and popped until i blipped the throttle and then settled
This is the fault code i have been getting all along, could this be the problem or is it something separate? Someone must have an idea?
Charge Pressure Control - Positive Deviation
I wish i could find out what this means
Thank you peeps
Thank you peeps
