dog bone engine mount
cupracooper
Somewhere in the middle
Jan 19, 2004
89
Warwickshire
I've got the full THS engine mount kit, I previously had an uprated poly bush but had cabin vibribrations at low revs.
Thought might as well do the whole lot. THS's FR3 kit is supposed to be 30% stiffer than stock, don't anyway of messuring it though. I know it's reduced wheel hop and car feels tighter and more planted.
cupracooper
Jan 19, 2004
89
Warwickshire
so you would recommend the THS FR3 over a poly bush???
Yep!
Poly bush is cheaper, but you have the hassle of fitting it. I had loads of vibration problems when I had a poly bush, I know others have had mixed success.
Recon it took bout forty minutes with a jack and a couple of tools to fit both engine and dogbone mounts.
sheffboy
avoiding potholes
May 25, 2007
655
I hated my poly dog bone when i first fitted it. I had it off twice to check the torque settings and make sure it had been greased properly but still never liked the low rev rumble. In the end dave DPJ kindly sent me a set of oem bushes he had lying around and i went half oem half poly. This feels much more comfortable but the INA track density mount sound the danglies, they'll probably be getting £100 of my hard earned cash very soon.
ryan106
87
Does anybody know how much THS do the Dogbone mount for SCN members as the TIP i got was cheaper than advertised on the website.
Mar 29, 2007
1,207
Berkshire
So it sounds like the THS mounts are comparable to the INA street density mounts. As I was going for the track density DBM I'll stick to INA in that case.
2footpegs
117
well because i ordered the two turbo hoses from them at the same time they said they could give me the dogbone for 45 delivered
Willie
LCR Track car
Aug 6, 2004
8,939
Sunny Scotland
Yep!
don't mean to question you but how did you do both engine mounts and DBM in forty minutes. You should get a job from F1;)
I'd recon 2 hours to do all three and two person job as lining up these mounts are very important. Copy of ELSAWIN gives all the alignment specs, new bolts are needed aswell as these are stretch bolts
cupracooper
Jan 19, 2004
89
Warwickshire
Easily done in under an hour.. did save quite a lot of time as I don't have an undertray on :)
Recon you'd be closer to hour and half by the time you'd taken off and refitted one of those.
Book time is only 1hr for both engine mounts, I reused my bolts.. same as most people. As for the alignment didn't have any problems. Only doing one side at a time (as opposed to engine out), there is minimal side to side engine movement.
Nov 29, 2007
736
Mansfield, Notts
... well I've gone for the THS mount. Ollie@THS has given me a great price for DBM and TIP. Don't know the exact price at the moment cause he gave me a combined price inclusive of postage.
turbin
I got the ECS bushes and torqued at stock nrs. Only a little vibration in the steering wheel at idle. Can hear/feel the engine more at higher revs, which is a very positive thing !
Nov 29, 2007
736
Mansfield, Notts
well after looking into it in a little more i decided to spend a little extra. Though getting the DBM and TIP sort before the remap was a must.
Hopefully the extra on the THS DBM will mean I get all the gains without the vibrations.
J0N
Defected!
I emailed THS and got a reply from Ollie stating their DBM comes complete with housing and costs £45 plus £6 p&p to SCN members paying with PayPal. If anyone is using one of these with OEM top mounts I'd like to know if they're any good.
james walker
cooling is the key people
May 24, 2007
5,121
retford notts
interested in the ths item, they are on the bay for 55quid plus post, do you get the whole mount as opposed to the bush?
45 plus 6 delivery is dirt cheap...
group buy is a coming i feel...
ryan106
87
I am also keen to know what this mount is like on its own without the other top mounts if anyone has this setup
Dyscontinued
1,142
Leeds
I've been thinking about doing this but wondered:
If you guys with petrols are commenting on the vibrations, is it a good idea to do it on my diesel cupra?
