Each to there own but you re running the risk of a bit of vibrations that you might not like
so you would recommend the THS FR3 over a poly bush???
well because i ordered the two turbo hoses from them at the same time they said they could give me the dogbone for 45 deliveredDoes anybody know how much THS do the Dogbone mount for SCN members as the TIP i got was cheaper than advertised on the website.
don't mean to question you but how did you do both engine mounts and DBM in forty minutes. You should get a job from F1Yep!
Poly bush is cheaper, but you have the hassle of fitting it. I had loads of vibration problems when I had a poly bush, I know others have had mixed success.
Recon it took bout forty minutes with a jack and a couple of tools to fit both engine and dogbone mounts.
