does this sound like MAF? quite worried!
Beaker™
Slightly Unhinged........
Nov 21, 2005
1,900
C:\UK\Glos
I knew it! :p Pop it back on mate, should be fine. If it happens again try a stronger clamp/clip. You wont 'need' the faults cleared (i'm not 100% sure it will even log a fault for this), car will run as normal. Engine management light will go off after a few days, mine did anyway :)
If it still pops off with stronger clamps then as Mike suggested, you will need a silicone reducer from Forge.
ibizacupra
Jack-RIP my little Friend
Jul 25, 2001
31,333
19
glos.uk
yes, pop it back on and replace the spring clip with a jubilee, and replace the heatshroud which should go round it. hot exhuast adjacent and rubber makes the hose goes soft and slide out from under weak clips.
Beaker™
Nov 21, 2005
1,900
C:\UK\Glos
That reminds me, must put my heat shield back on :thumbup:
nick s
256bhp & 282lbs/ft
Dec 9, 2005
396
yeah and me. mines in my boot from when we fitted the K03s!!! :D
i have put the pipe back in, will buy a jubilee clip and swap it when i get a chance :D
AnOrO
I'd put money on it being a hose popped off somewhere on route between airbox and inlet manifold (turbo/intercooler etc). Unplug each coilpack one by one and start the engine each time. If when you pull one the problem gets worse then its a coilpack. If the car behaves the same after removing each one then i'd check your pipe work for a popped off hose.
Same thing just happened to me. But the pipe that popped was the one that is conected to the left intercooler. Thanks to this post it was an easy fix, :clap:
nick s
256bhp & 282lbs/ft
Dec 9, 2005
396
mine hasnb't popped back off since i swapped it for a jubilee, i'm hoping another pipe popping off is the cause of my current no boost and funny noise issue! but i've got a feeling i'm gonna need a new turbo!
