I knew it!
Pop it back on mate, should be fine. If it happens again try a stronger clamp/clip. You wont 'need' the faults cleared (i'm not 100% sure it will even log a fault for this), car will run as normal. Engine management light will go off after a few days, mine did anyway ![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
If it still pops off with stronger clamps then as Mike suggested, you will need a silicone reducer from Forge.
![Image024-1.jpg](http://img.photobucket.com/albums/v480/nogutsnoglory/Image024-1.jpg)
