Matt Cupra R
92
Berkshire
I have done a search but not found these exact symptoms.
I have a 55 plate LCR 225 with 6,000 miles on the clock. THe only thing I have changed is the DV for a 007.
Here's the problem, the car pulls fineand if you floor it everything is fine. Although if I am accelerating on full throttle and back off and then re-apply full throttle, the car does not pull. It's like it has no turbo. It accelorates but not properly. I am talking about when it is above 2500 rpm so it is not that the revs fall to low. It's like the turbo stops spooling.
Has anyone else had this problem?
The valve was supposed to have been serviced before I got it. If not, what do I need to do? Is it a case of taking it apart and putting some grease in there?
