Thanks for the comments guys. The last week I have been working on a decent heat shield for the larger filter to enclose it and also support the tip and maf housing.
Started with lots of cardboard and making templates and adjusting them until I came up with one I was happy with.
Then got a sheet of 2mm steel and marked it all out and got to cutting it about. Long hard job with a zigsaw. Next time use thinner material or alloy lol.
Once cut out I fitted the red trim to it and trial fitted to make sure of figment.
It needed a bit of fine tuning to get it just right but not a lot. Happy so far.
Then another template to make a floor to seal it off from below.
Then trial fitted again.
Next I bolted the two together.
I then used a bracket to fix the filter to at the front edge on the grill air feed.
The last thing was to crinkle black paint it and put it all back together.
