okey not the most exciting of modifications....but:
horns!!
my horn was shagged, so it needed replacing. The standard one is 2 trumpet like horns:
I found that on my old 51reg leon it filled with water (located behind the left side of the bumper). On my LCR they were originally located behind the number plate, but had to be moved to make way for the intercooler, so put them back to where the left side mount intercooler was (see earlier pics about the intercooler install)
Anyway, i wasnt going to replace them with the same type as i really cant be arsed having to change them again, so went for some electromagnetic ones (like my dad has on his volvo)
Easiest way was to remove the passenger wheel, and wheel arch lining to get to the horns. Once the old ones were removed, had a nice gap to play with:
The standard horns have a fancy clip on them, which had to come off so a snip and new plug later (new plugs on left, standard on right):
Couple of pics of the new ones bolted in:
I've put a bit of black tape around the terminals to make it a bit neater.
Not the most interesting of updates, but its an update nevertheless
Least it will pass its MOT on weds now
