Dashboard like a Christmas tree help!!!
kaluharu
10
Ok so posting again in one last final attempt before the car goes the journey.
Auto electrician has had the car, it's driving fine, no faults whatsoever. Everything is working.
He's said that the rear tyres are different brands and different tread depth. Left rear loses air a lot, possibly slow puncture that'll be explored once I have the car home.
His theory is that because the pressure is low it's throwing all these fault codes.
Anyone in the know that can back this up? I can't personally see it being the issue but he's recommended swapping front to back and seeing how it goes.
Lost all faith now with it losing power on me on a fast road, I can't see how loss of tyre pressure (no warning light for it also) would cause this?
kaluharu
10
SOLVED!!!!!
What a run around I've had with this bloody car! After seeing multiple mechanics and a rather useless auto electrician it turned out to be a relay in the fuse box that was burnt out.
Thankfully the trusty mechanic I usually used witnessed the car in action, or rather out of action and refusing to turn over coupled with all the warning lights. After a lot of digging he found the problem.
Was literally days away from selling the blooming thing!
johnnygal
22
7
Super. Chuffed for you. I can imagine the relief you have that it's sorted.
Which relay was it? (Your link takes you to the resource pages, but can't see anything from you, maybe it's not been approved yet)
