Well, this is turnign into a big build thread soon... It seems to burn a bit of oil first start in the morning after a fastish run the night before, I had hoped this was turbo seals. but with the new turbo, its still as bad. Now, its fine if driven gently, wont burn a drop.
So looks like i'll be Building up a stroker, will get this mapped, and run it until it pops whilst building a 2.1
*PLANNED SPEC*
2.1 bored and stroked 20vt
using IE Rods and Pistons
New 1.9D crank
Every single load bearing bolt replaced with ARP
SMF and probably a bigger clutch again.
Probably GT3071, or, I might keep the 2871r as I really like how it drives, but a bit more off boost torque wouldnt go a miss.
Gearbox will be treated to a full recon using diesel gearing and a quaife.
