DAB radio & heated rear window
stevemc81
148
16
Does anyone else lose DAB radio reception when they turn on the heated rear window? Bit annoying when you're de-misting.
Marve
191
9
Not for me. I use the DAB radio all of the time and definitely put the heated rear window on at the weekend and didn't lose the radio.
derelyth
295
Portsmouth
Tested for you before leaving work tonight. No loss of Team Rock Radio with the Rear on so I headbanged the whole way home :-D
Sent from my Nexus 4 using Tapatalk
Jul 29, 2013
859
Essex
Mines ok. It could be some random RFI. If you have a little portable radio tune it to am 550 and see if you get **** loads of noise out of it when you turn the heated window on
derelyth
295
Portsmouth
My other thought - if the aerial for the DAB isn't near the rear window, could it be a dodgy earth somewhere?
End of the day it's under warranty so let the dealers scratch their heads whilst you put a courtesy car through its running in period in 2 days straight.
scrich7
311
Bedford
I could be totally wrong, but the DAB aerial might be in the rear window? So possibly a short somewhere
Sent from my Z10 using Tapatalk
@JamesSM
76
I use the DAB all the time and have never experienced a loss of signal when using the heated rear windscreen.
Does anyone know where the aerial is? I've always assumed it's built into the rear spoiler?
stevemc81
148
16
I'm going to try it tomorrow when I'm in the centre of Glasgow. Could be that my house is in a marginal signal area.
Pretty sure the aerial is in the rear window, think that's what the vertical lines are.
stevemc81
148
16
Well I've had the chance to try this again in a few different locations and it appears to be working fine, which is odd but good.
I've noticed some drop off in reception driving about my home town so the original problem could well have been due to a very marginal signal to begin with.
stevemc81
148
16
I never bothered taking it back to the dealer to get it looked at as it's pretty infrequent that I have the radio and the heated window on at the same time, but it does still affect me.
I've decided to just mention it to the dealer when I take it for it's first service and see if they can find any issue with it then.
Ssgvickers
I had the same problem. Seat informed me the antenna for the DAB runs through the rear screen and can short. They replace the back screen
Just had mine done last week and now working fine with the DAB and rear screen heater on.
They are aware of fault
Hope this helps
stevemc81
148
16
Hope this helps
Excellent, cheers for the info.
