CV Joint/Boot or wheel bearing?
sargey
Escaped mental patient
Aug 16, 2006
324
Weston-super-crapland
Ok, going down the motorway or over 65, the steering wheel has speed wobble (its not traction or tyres or balancing, had them all done)
also when breaking at that speed(hard ish), the steering wheel wobbles
could this be a wheel bearing problem or cv joint/boot problem or something else maybe?
Willie
LCR Track car
Aug 6, 2004
8,939
Sunny Scotland
As above, check to see how many weights there are on the alloys to balance it. If its anywhere near 100g then points toward bent wheel. Most likely to be warped discs as above
sargey
Aug 16, 2006
324
definately not the balancin as i got it done the day before i went on a long journey up the motorway and it was still happenin
warped discs surely would give bad braking? i had to break hard the other night and the braking was fine
andycupra
status subject to change
try swapping front and rear wheels.
i had a wobble issue for ages, wheels were re-balanced twice, tyres changed, lots of checks done and still had it.
Swapping of wheels solved it.
