loopyleeinbath
Alright all, Newbie member here with an intermittent problem. Had my cupra 180 (no mods) for nearly a year now on a 2000 plate. Has been running fine until a month or so ago. Had a sudden intermittent drop in power, then it would be fine, then not and so on. at worst, you can be in any gear, put your foot down and the car wont accelerate any faster, then all of a sudden it would be ok and it would tear off.... In idle, and when the problem is current, the rev needle seems to jump up and down a bit, and when in neutral, if i give it some revs, i sometimes get a missfire, spluttering ect. Also a number of times as ive come to a junction, dippped the clutch and its stalled. Cars been at a local garage for a while now, been plugged into a computer, a few error codes were present such as a missfire on one and 2 sylinders, and an air pressure sensor. Garage said something about a P code?? There are not cat problems, pipes are all ok and keeping pressure. before i took the car into the garage, it went almost into a limp mode and had hardly any power at all. Errors were cleared on the ecu and it was ok for a few days then went back to the same problems. The garage are scratching their heads so anyone got any ideas?
Cheers.
Cheers.
