2 bar overboost, immediately stabilized at 1.8 for the reliability.
274.9 Hp / 506.5 Nm are engine result to the bench.
Stage 3 with GT2256V modified in GT2260
Cylinder head prepared
Bigger Injector 1043
Camshaft machined
I checked the pressure with VAG-COM, they are OK.
I publish the report soon to of bench.
I run a similar spec (same turbo, with headwork injectors and cam) and mine peaks at 2bar and is making similar power to that
It should not be confused with a stock turbo with a turbo that has a larger turbine.
