I tried fitting cruise control today, and I thought everything was going well... Have just finished wiring and recoded the ECU. No fault codes were found when it was running, but when I turned the cruise on (engine idleing, not being driven) the engine cut out. Vag-com found a fault to say that there was an implausible signal. I restarted the engine and then pressed the resume button. The engine then cutout again. The set button does nothing.
So, questions are:
1) Are these problems being caused by it just idling and not moving
2) Are the wiring connections as follows;
brown connector xs3, stalk connector
5 to 31
6 to 30
2 to 27 ?
3 to 26 and 29 AND connects to white ecu wire (pin 14 T121 connector)
28 switched power
ANY help would be appreciated!!! PLEASE HELP
So, questions are:
5 to 31
6 to 30
2 to 27 ?
28 switched power
