right, the activate oken button is greyed out on mine? have I cocked something up?
And this software doesnt work with all comfort modules. For eg. it didnt work on mine 2000 x reg Cupra unfortunately.
can't get it to work on mine. Starts running through code, comes up with a number of errors with "echo" in them, and then something about incomplement ECU and then time out? Am I being a spanner?
yep, and when I load it says activated![]()
hmm but it should work if you can connect to the comfort module with VAG-COM on the same port and cable?![]()
http://www.motordiag.eu/mkm/index.php -Supported vehicles
supports Leons 2001 and after, sorry
I'll have to have a go at this too. Need leads though. Will it work with a MacBook?
Mark many congratulations bud!!!
Why not try with the original Rosstech drivers first since you have these installed?If I change the drivers to some generic ones rather than the proper Ross-Tech ones, is this likely to work with a proper KEY-USB Ross-Tech lead?
Great post, about to have a go, looking at the extended functions for the locking it shows:
automatically locked while driving
automatic unlocking when extended loop
via google translate, first one is obvious, whats the second?
Edit to say, just done the windows - works a treatAlso bizarrely when it checked out my cars extended features it showed both the above were ticked, however my car doesn't automatically lock when driving?!?!
