COOL remote windows feature available now!!!
DannyC87
Rubbing is Racing :-)
Mar 4, 2008
3,459
can't get it to work on mine. Starts running through code, comes up with a number of errors with "echo" in them, and then something about incomplement ECU and then time out? Am I being a spanner?
DannyC87
Mar 4, 2008
3,459
hmm but it should work if you can connect to the comfort module with VAG-COM on the same port and cable? :think:
ya, I will go try again and make a note of all the errors so I can translate them. Will load vagcom first and login to convenience mod to make sure all is well there.
DannyC87
Mar 4, 2008
3,459
well it seems using vagcom first opened up the channel - it worked perfectly this time! Spot on. thankyou very much Hara, i'm sure a number of people on here will be very grateful!
Sparkie
Angling Adict.
Sep 25, 2009
2,541
779
Middlesex
I'll have to have a go at this too. Need leads though. Will it work with a MacBook?
Mark many congratulations bud!!!
George 3G
KW & Weitec
Jul 28, 2009
465
Herefordshire
Thank so much Hara, was a bit tricky but got it done!
My main stumbling block was some Czech message about COM1. Checked in device manager and it was set to COM3, changed to COM1, ran software again and worked.
Thanks!
hara
170
continent
If I change the drivers to some generic ones rather than the proper Ross-Tech ones, is this likely to work with a proper KEY-USB Ross-Tech lead?
Why not try with the original Rosstech drivers first since you have these installed?
I think it is very likely it will work as long as you can access the comfort module :)
FYI I used a KKL cable which, according to the description, has 2 K lines switched by an L line.
I have no idea what that means but here you go :D
ScoobyJawa
Achtung!
Oct 2, 2002
449
Liphook
Visit site
Great post, about to have a go, looking at the extended functions for the locking it shows:
automatically locked while driving
automatic unlocking when extended loop
via google translate, first one is obvious, whats the second?
Edit to say, just done the windows - works a treat :D Also bizarrely when it checked out my cars extended features it showed both the above were ticked, however my car doesn't automatically lock when driving?!?!
hara
170
continent
probably auto unlock when removing key from ignition :)
have you tried setting it with VAG COM instead?
