COOL remote windows feature available now!!!
Feb 26, 2009
5,275
Wolverhampton
Only on certain convenience modules. For example, mine uses a set of four codes, one for each of the windows. Most cars use a set of three codes, which are fault tolerant copies of the same number.
jamie8954
Diesel FTMFW
Jun 29, 2008
553
UK
thanks for this....
im just wondering if it will work on a 2007 seat ibiza fr mk4
it doesnt say it is supported but who knows ?
Also Motordiag Comfort Manager FULL 2.0 says it is supported can you buy it off the site or does anybody know where i can download it ?( PM ME )
robno1
any one in south london (near sutton/croydon) able to do this for me? beer or money can be paid :)
cheers
robno1
Does anyone know if this works on mk4 golfs, its a GTI (none turbo)
Windows go down if you hold the key in the lock so im guessing it would be the same.
Any info would be great.
cheers.
jamie8954
Diesel FTMFW
Jun 29, 2008
553
UK
cheers.
the KVW100 will work on golf mk4 definatly 100% but im not sure about this way , just try it mate if not you can deactivate it :)
Feb 26, 2009
5,275
Wolverhampton
thanks for this....
If your Ibiza uses the newer CANBUS then no it won't work. It's only the older OBD ones that work.
Feb 26, 2009
5,275
Wolverhampton
cheers.
I'm fairly sure the VDS-Pro option will work, the Czech software is a 50:50 bet but worth a go, and the KVW100 is 100% but I wouldn't recommend it at all.
robno1
Hi a friend popped over last night and we managed to use vagcom / VCDS (pressuming lite as it wasnt DOS)
and got the the lock/unlock beep to work :)
couldnt find where the window unlock is? can any point me in the right direction?
also we used an OBD2 to USB lead but when i ran the motordiag software it wouldnt allow connection, just said cable not ready or incorreclty connected, tried on 2 lappies and was 100% on the correct port.
any help would be great :help:
Feb 26, 2009
5,275
Wolverhampton
Vagcom/VCDS won't do the windows. If you tried the motordiag software and couldn't get it working, check the earlier posts in this thread as other people have had similar troubles and got it working.
stevie steve
322
Clevedon
Im in the bristol area with a 52 plate cupra
Anyone nearby I can visit to sort out the windows for me.
I did have one of those plug in, wait for the beep units. It never worked, just beeped intermitently.
My keys can make the windows go up and down, I think this one of the things you needed to check it worked with the OBI plug in stick.
