Guest, 🚨New Stock alert: Premium CUPRA valve caps now available in the store 👉 Order now from the merchandise store
My Green Cotton arrived today, via very swift 'next day' delivery - thanks Badger 5.
OK, I'm probably being dumb - but how the foock do you open a LCR's airbox to change the filter??!!
I've undone the 2 screws & it won't budge - do I need to disconnect anything else? (Don't like the look of those scary 'big pipes'.)
Thanks.
lol. its easier if you disconnect it from the 'big scary black pipe'D) but you can just carefully wiggle it out of the two teeth that it slots into towards the battery side of the box and flex it up. Be ver careful though cause you dont want to go killing your maf!! I usually disconnect the two little screws that hold the box to the pipe with a small screw driver.
