changing injectors??
Jan 8, 2007
2,958
Wiltshire
Reviving an old post; I'm changing my screw-in seats in the inlet manifold but can't find a tool big enough to do it??
Looks like it needs a ~20mm allen?
Has anyone else done these lately and if so what with/how?
-pseudonymous-
681
Ive got a sneaky feeling its a 19mm allen key you need Robbie. Just be careful removing the old seats as they are prone to shattering when you undo them. Your probably best off using a 19mm hex bit to use on a rachet although i just made do with a normal allen key. Also you might find the old seats unscrew easier if you run the car before hand to warm the inlet manifold up.
EDIT: Be careful not to cross-thread the new ones when screwing them back in as this is easily done.
Jan 8, 2007
2,958
Wiltshire
Cheers Ollie. The old ones were taken out in one piece when I had the inlet mani powder coated last week and they look to be OK but I've already got some new ones on order as I hear theses are prone to leaking boost.
I'll be using some silicone sealant to help put them back in which I bought to seal my baffled sump on
ian_cupra
shouldnt need any sealant mate, i never have, not leaks either, they are such a tight fit
h17och
the hunt is over. 460bhp
Sep 1, 2005
3,504
Dunstabubble
they do need sealing.
do a boost test after
find a19mm headed bolt.fill the shank up with nuts and tighten them.then use a 19mm socket and ratch on thenuts and use the head of the bolt in the injector seats to undo them
Bolland
74
I think someone ssaid you can just use some PTFE tape. One of my injectors is leaking, the guy who had it before me swopped them for TT injectors i think, could this be the reason why my pressure gauge is showing -30 when idling?
