Changing Fuel Filter
Guinness
Finally got the BMW
Nov 29, 2006
4,422
Newcastle
Baisicly just wondering if its a hard job as mine has never been done and looks a bit dodgey. Also bit skint at the moment so just wondering if its a DIY job?
redders
75
make sure you fill the new filter with diesel before you fit it as well or else you will probably flatten the battery trying to prime it :)
redders
75
not sure but for a genuine one a think you can pay towards 20 quid maybe even a bit more now
CHR15B
2,567
9
Scotland
Fuel filter isn't expensive and is easy as above to remove.
Getting the two rubber pipes on and off is a pain in the backside though ... got to pinch the clips with pliers and pull them - I've always hated doing it.
muddyboots
Still hanging around
Oct 16, 2002
5,739
I usually use molegrips to pinch and hold the clips loose while I pull the pipes off.
Make sure the drain on the bottom is tight ;)
Also make sure you've got the right filter before ditching the old one.
The first one given to me by the dealer looked identical on top, same fittings etc, but was 2-3" too short and dropped right down the holder.
